Hi there,
I am using a Windows 7 laptop. I am not having the Windows Movie Maker. But, I would like to make some video along with the simple text and photos and my own mp3 song playing. I don't have any software which does that. I am looking for some freeware which allows me to do that. Please help me to create the same. Your help and support will be gratefully appreciated.
Many Thanks for your help in advance!!
How can I make a video my own
I would recommend you use the following software alternatives :
1. EZVideo : this is a screen recorder, a slideshow maker, and video editor. With this you can record your screen and capture whatever appears in front of you: websites, games, music, videos and more. You can edit movies or videos by changing their speed, re-arrange a clip order, add text and image slider. It is an elegant and free video editing tool.
2. Jahshaka : it's a free open source video creating platform than delivers a powerful and immersive media management and all this accentuated by a series of modules for animation, composition and other special effects. It offers you rapid experimentation with different types of effects in real time by CPU based image processing.
3. VirtualDub : a video capture and processing utility that is streamlined for fast linear operations. It can process large amounts of files and it is mainly geared toward processing AVI files. You can use it for capture and encode whatever you need done, or edit the videos that you already have, although keep in mind that this is very lightweight and does not compare to the version mentioned above.
