How can I migrate from 2003 to 2010?
I have migrated to 2010 from 2003. I had used custom forms in 2003. I have also used ‘Current item Convertor ‘add on for changing the forms to custom form. Is the option available in 2003? Please guide me. I will be thankful for all help and support.
Best Answer by anamulmoni
Answered By 0 points N/A #98608
During migration from 2003 to 2010 you can encounter such an error, so you should pay attention to two sessions in the SCHEMA.XML file. This list types are very important for the purposes of accurately customizing the forms. There are two elements:
1. The opening Fields element that is used to define special fields for the list;
2. The Form element that contains the form view for each form type.
Keep in mind these guidelines and you'll be able to fix the problem.
Answered By 0 points N/A #98609
no this option is not  available to 2003.
Answered By 0 points N/A #98610
It guide me alot. Thank you for the information..
