How Can I Monitor My Network Traffic Through Different Ways?
Network traffic is an important part of the usage of the computer. But hardly anyone knows about it. How can I monitor my network traffic?
Method 1-
Step 1: Download and install Wireshark and WinPcap and open it.
Step 2: Choose Interfaces after clicking the Capture menu.
Step 3: Click on the Start button and then go to Capture menu and then Stop.
Step 4: Examine and analyze the list of packets.
Method 2- PRTG Network Monitor: It is an affordable network traffic monitor that helps you in managing your traffic the way you want to. It helps in spotting the problems. It displays data in easy-to-read graphs and tables with the use of bandwidth tool. You can send this data as a report .
Notifications
