How can I open adobe reader x10 speedup on my Mac?
I am unable to open adobe reader x10 speedup on my Mac. I have used the same software in windows. But it shows some “Active x 11” error message.
Can someone please explain me why do I see this error message every time and How can I solve it?
Answered By 10 points N/A #191510
Follow these steps.
For Windows :
1. Login as an administrator in your windows.
2. Click to visit and download this file Acrofix from Adobe site.
3. When downloaded it will prompt. Click on Open.
4. Start extract the file. It will depend location on your utility and system.
5. When extracted Click on Acrofix.exe for execution.
6. The execution gets successful then the command prompt will close by itself.
If the problem persists try this.
Solution # 2
From Command Prompt :
1. As an Administrator run Or go to command prompt.
2. Go to the extracted files in solution 1 check the 4th step where you save the extracted files.
3. Now type the Acrofix.exe and press enter.
The execution gets successful in the command prompt
4. The execution gets successful in the command prompt it will show you exit code 0.
5. Now you can Launch Acrobat Reader.
Answered By 5 points N/A #283053
Clean up your Mac computer before it’s too late…
I don’t need to tell you Mac computers are expensive, because we both know that!
So I also don’t need to tell you either that it’s in your interest to keep your Mac computer tidy and clean. A trip to the Apple repair store can be costly and stressful. Believe me, I’ve been there.
So what can you do?
You can detox your Mac using Detox My Mac! Detox My Mac is the #1 Mac cleaning application out there right now and every second is saving users hours of waiting and hassle with their Mac computer.
Download Now >> http://adfoc.us/37141461107244
Not only will Detox My Mac remove unwanted and unnecessary files such as cache files, logs and application leftovers, it will greatly improve your Mac’s performance, speed and responsiveness.
It’s like a Mac upgrade in seconds!
The best part of Detox My Mac is it does not affect a single application or setting. The only difference you will notice is a faster and cleaner Mac, with a ton of extra disk space.
Scanning over 30 advanced elements in your Mac, I can tell you now you won’t find a more comprehensive and safer Mac cleaner out there.
Priced at $37.95 – Personally I think that’s a drop in the ocean compared to the extensive cost of a Mac repair or upgrade. What price would you put on your Mac’s health and speed?
My advice: Check out their website and see for yourself Detox My Mac in action!
Watch Video >> http://adfoc.us/37141461107244
Speak soon,
PS. To put your mind completely at rest, you can grab a copy of Detox My Mac with zero risk through their rock-solid 60-day money back guarantee! Now that’s pretty darn good if you ask me!
