Hi all,
How can I open pps to ipad? I have 22 files with .pps file extension that my friend emailed me about the upcoming school tasks and was unable to open it in my computer for I don’t have a Microsoft powerpoint installed. Is there a way I can open the pps file extension in my ipad?
Thanks and have a nice day.
How can I open pps to iPad?
Hi Davis Miller i searched some solution that may help you solve your problem.
1. Search Google Docs on the internet.
2. If you do not have an account, create one.
3. Download those emailed files.
4. On your Google docs Account click upload and select those files that have been emailed to you.
5. On your Ipad Open Google Mobile. Â Use Safari on navigating
6. Select the PPS that you uploaded in the Google Docs.
Yes there is the easiest way is to use "Safari" web Browser. You can also use a software called "Good reader" which is developed specially for iPad. If you want to edit them or create new ones for yourself then you can use "Keynote". Also you should be able to click that is touch on the attachment to download them and then use one of the software to use them.
