How can I open xlsx file in excel 2003
Asked By 130 points N/A Posted on -
Hi, there is any one can tell me how to open an xlsx file Microsoft excel 2003 as I have tried many procedures, but I fail is there any procedure to convert this file into Microsoft word file or I can simply open this type of document in excel 2003.
Answered By 0 points N/A #185285
Below is the procedure to open the file xlsx file in the Microsoft Word 2003.
Open the Microsoft Word 2003 go to the Microsoft logo on the right corner. And then go to the open.
Find the xlsx file that you want to open. Select the file and then after that it will open. And then click on the save as in the menu. And it will display the options and you can select any version in which you want to save it and save it as. And it will also change the version of the file into the Microsoft version in which you saved the file. And then you can easily open it.
