Hello experts,
How can I perform windows xp repair? My 2 years old computer desktop with an operating system of windows xp is having a problem, it reboots automatically when a webpage automatically pops out in my desktop. I think it was a virus and the registry system was infected as well. How can I resolve this issue?
How can I perform Windows XP repair?
You have several options to fix your problem:
1. If you have an antivirus that is capable of cleaning infection, try that first.
2. If you don't mind losing your saved files, you can reformat your computer using your windows xp cd. You can try to backup your important files first before doing this via usb flashdrive or cd/dvd burn.
3. If you don't know how to do those things, get a tech to do it for you. :p
First Option:
Use an antivirus to clean-up some unwanted software or restore your computer if necessary.
Second Option:
If the first options didn't do any help, you can ask a computer technician to solve your problem.
Hi Kristen James,
First, use System Restore, to restore your computer at the time when it is running smoothly.
Second, use antivirus programs to clean up some unwanted software.
Third, use registry cleaner to clean your registry.
