How can I play audio dat file android mobile
I have a Samsung S2, with me.Â
Please suggest a way to play audio dat file android mobile phone.
If any software can help in this regard, I would prefer free wares.Â
Thanks in advance.
Thanks in advance.
Hello Amber Ward,
Which video player do you use?
I suggest you try playing the Dat files through Dice Player.Â
Go to Google Play store and install it. Here is a link:
Another way out is that you can install a video converter application in your phone and convert Dat files to known formats that you phone supports.Â
Hi Amber,
I would suggest following freeware software for your Android phone which has advanced capability and also supports a wide range of codec and file formats.
Click on the link to get that one KMPlayer.
However you might be pleased to know that it also supports windows 8 operating system.
Hope it helps.
Thanks
Baker
