How can I play flash sample advertisement without finalizing it?
I want to check how my flash sample looks like without having to finalize it. Where and how can I play flash sample advertisement without finalizing it?
Hi! Good day!
Yes you can check your flash sample while doing the project even without finalizing. If you’re using adobe flash you can press ctrl+enter to preview you work. The files will become .swf during preview so it’s playable while you're doing your project at the same time. If its different application, they have the same shortcut to preview your work while making a project.
Hi Cruz!
I found out that you must first install Adobe to go on playing flash sample advertisement without finalizing it. You can visit this forum to learn more because it is related to your topic.
Link: Â https://itstillworks.com/12324223/free-games-to-play-without-downloading-anything
Thank You!
