How can I play swf flash win32 Windows?
I am running a machine with win32 Windows operating system. I wonder if I can play swf flash win32 OS using some media player application. Any idea?
You can play SWF flash in windows 32 operating system on your media player in addition to any flash players.
You may download SWF & an FLV media player from http://download.cnet.com/archive/3000-13632_4-170532.html that will allow you to play both SWF and FLV formatted flash video.
Again http://ptf.com/ link contains some SWF flash player and Downloader. You may try those too.
Hello Davis Avon,
Swf files are adobe flash files; they can usually run in a browser as flash player plug-in is installed in them. If you want to play this format on your desktop, there are two ways, I will give you both.
1. You can download and install Swf Player to your computer and run these files. Here is a link to such software:
2. You can convert the swf file to known formats and then run it. Here is a link to Swf Video Converter:
Thanks, experts, for your valuable information. Barbara Miller, you have explained the two ways to fix the problem. Both are good, but I like the first one more, because SWF Player is an application that allows me to play video clips with the SWF format. This is a portable software, so installing SWF Player is not necessary. It means that I can place the tool on an external device and directly run its executable files on any computer. Really, your provided solution is superb, and now I am using this software too.
