How can I possibly convert flash exe to mp3?
Hello techyv,
How can I possibly convert flash exe to mp3? I have some flash .exe files that need to be converted to mp3 format, can you share some licensed software that will allow the user to do the conversion? And also give some instruction on how to use the said software.
Expecting some help from you guys.
Best Answer by jeffe meeks
Answered By 0 points N/A #179037
If you want to convert flash exe to mp3 you have to use a software which converts .swf or .flv file to mp3.
If you want to convert the file directly using screen-capture software it’ll take a long time.
Basically flash exe is the flash projector which you get from flash so you have to convert the .swf or .flv file which you are using in the .exe file.
You can use the Moyea SWF4 TubeConverter which is available in internet for the conversion or
You can download another software by clicking the link.
Answered By 0 points N/A #179038
The flash is an interactive file format so extracting audio directly may be a problem but you can first convert the .exe to SWF Shockwave Flash then extract the audio.
To convert the .exe to SWF, you can use this software FardaSaz EXE to SWF (as far as I know there is no licensed software that can do that).
Now to extract audio from the SWF, download SWF Extractor which is software that gives you the ability to extract all the images and sounds that come from a movie in Flash format (. SWF format). The images are taken in JPEG or Png and sound to audio formats MP3 or WAV.
