How can i post more posts other than Home Page in blogger
Asked By 110 points N/A Posted on -
How can i post more posts at blogger. I can post more posts at Home page but i don't know if i create another page then how can i add more posts at another pages in Blog.
I know how can i post more posts at home page but i don't know how can i post more posts at other pages that is created in blogger.
Please tell me pictorially.
Best Answer by rosalia85
Answered By 0 points N/A #83718
Hi Shaheen ,
  • Actually , it's not a big issue .
  • You have 2 options or choices to post more than one posts " multiple posts" other than home page :
  • First choice , you have to create static page and format it manually  to multiple posts.
  • Second choice , create an index for your blog and link it with other pages .
  • Hope that 2 choices will help you to solve this problem . However , I recommend to try the first choice.
  • If you need further information , please let me know .
Best Regards ,,,
Tom .
Answered By 0 points N/A #83719
I recently received my Virtual DJ Music software yesterday. However, it has the same issue when I was trying to fill out the form for the MK2 version. I disabled the onboard sound card then, right click on the "My Computer" page then, i went to properties area and choose "Device Manager". Then, I scrolled it down to the sounds and the succeeding settings. After that, I right click on the on-board "Realtek"and disabled it. Then, I go to the control panel and uninstall Hercules DJ Series Driver from "Add/Remove Programs".
Next is that I started to download the updated drivers from the Hercules web site. It will contain the recent drivers and the firmware update on oner RMX if needed.
After that, reboot oner computer and install VDJ5 console edition. Then, launch the "Hercules DJ Control Panel" and choose "ASIO" then start VDJ Pro.
For oner reference here is the set-up on my own desktop:
1. A thermal LanBox case with five cooling fans.
2. Asus PGX 512 MB DDR2 ram video card for graphics.
3. A 320 GB SATA WD Hard Drive 7200 RPM.
I hope this would be helpful in finding answers in oner problem when installing Virtual DJ Music.
Rosalisa85
Answered By 0 points N/A #83720
There is two ways to create multiple posts.
1. Make your static pages with multiple posts, manually formatted.
2. Make a custom pages / posts index, and link to dynamic pages, based upon label retrievals.
