How can I preload the dash in OSx?
Can you please tell me how to boot up with the dash hidden? Okay, so I'm new to Mac and this is probably a simple inquiry. So far, I've figured out how to set something to automatically run and how to make it invisible in sys prefs -> consideration -> Sign in products.
My issue is that this doesn't work with the dash. I've found the dash.app, chosen it, and checked the invisible box; but it still shows up. Of course, I don't have to run it automatically, like Skype, but it requires a lot of energy and effort to do this after start up. So, I would like to preload it at start-up.
My concern is that if I cannot begin it as invisible, how can I preload it to get the same effect? I’d like to thank you in advance. It will be great to receive your support.
