How can I print my images with my printer?
I bought a new printer Cannon 2772. I also have a software like Photoshop.
Thank you for your answer.
You have a printer and Photoshop. Now you need 2 more things to print. One is your printer driver soft. Another thing is image or photo.
First install your driver; you may have the driver soft disk with the printer. Insert the disk and install it. You can also print photo, using that application, which is provided by Cannon. Now open Photoshop and your image in it or select the image which you want to print.
Then go to the file menu in the sub menu select “print with preview” ; then a new window will come up; now uncheck the button left to the center button and check, ‘show the bounding box’ and position your image. Press ok ; then select your page type from properties and press OK.
You're done!!
Hello Conilive,
First of all, you need to connect the printer with your PC and then install the printer drivers in your PC by inserting a CD you got with the Printer. If you don't have the CD, you can download it from the Internet, just Google it. All you need to know is the model number of the Printer.
After installing the drivers, configure your printer by going to the Control Panel; select Printer and Faxes ; select Add Printer and then select Next. After that, click on local printer connected to the computer. Also click on Automatically detect and thats it you're done.
You can now insert a page or an image in your printer, preview it and then print it. Happy Printing.
Thanks!!
You need to first check the installer of the printer, if it is compatible with the Windows. If it is compatible, try to install the drive of the printer to your computer and after finishing installing on the drive, check if it is installed properly on your computer to avoid errors. Make sure you put the ink to the printer.
Always check the wire or cable, if it is connected to the computer. Always use original coupon band to your printer to avoid any problems while printing. If there is a problem or error, just check the printer to see if there is no ink or is not properly connecting to the computer.
To print images, just open them with an image editor like MS Office picture manager or Windows picture viewer. While there, click on file then print. In the print dialog box, set the specifications of the print page: For instance. Do you want multiple images per page or a single image? Choose the paper size; whether A4, A3 etc.
Alternatively, you can export the image into a Word document and print from there. Here you have to specify the paper settings because the default setting is A4, unlike in the picture managing programs where the default setting is set to the format for printing pictures.
Hope this helps.
__
Regards
Lee Hung
