How can I print a word document?
I write a word document and I want to make 3 copies from it but I am new user for Microsoft office so can anyone help me with this situation
Hi there I think I can help you with your problem. Any way you can use the steps I am going to say to print any document or file or presentation or excel sheet any Microsoft office program
First you open the file you want to print then go to menu bar under the page title press on (file) then you will see a window choose print and you will see another window . in top of it you must see your printer driver name and on the right of the print window you will find numbers of copy you can changed as you like and in the left you can choose to change page range and the print what option. here are pictures to help you
I hope my solution is satisfying
Regards
Hi there,
I am trying to give a solution for your problem.
Firstly open your word file then press Ctrl + P to open print wizard or click the print icon in the toolbar at the top.
Then you will find your print wizard, type the number copies which in your case is 3 and press OK.
I hope my solution will help you.
Regards.
