wafakhan
10 points
Posted on - 11/07/2012
You were trying to have it installed on your Windows, warning “Unable to download missing Microsoft DirectX® component, download it on https://www.microsoft.com/en-us/download/datails.aspx?id=35%E2%80%B3?
Ensure Internet connection is working properly re-run the Winamp installation when antivirus program are temporarily disabled, make sure a successful installation of the player program.
I get this any help
How can I properly install software winamp exe get this any help
Which version of Winamp are you installing? And on which platform are you installing it? Assuming you're installing it on Windows XP, just make sure you have most updated DirectX installed, as sometimes this may present incompatibilities.
You can download DirectX from Microsoft. Also make sure you have downloaded the latest version of Winamp. Some versions of this program already comes with a DirectX installer.
If you have tried installing over and over again and the error message still appears, then it seems that you will need to download a new installer. The file you have is corrupt.
Hope this solves your problem.
