How can I protect my computer
Hey,
It would have been very helpful if you could provide the question in detail like; which portal user password has been accessed unathorizedly? Who is the user? and the like.
Anyways, I could give you the solution assuming that your Gmail password has been known to other users. Just follow these steps:
I hope you got the solution.
Cheers!
Aemmy
If someone knows your password then you are on a big risk. If you an individual will be able to steal your info and also be able to take your important files, then all of these will leak. One can use your computer and can do anything with whether you do not desire or gave your permission.
To protect yourself, you need to take these steps:
Take these steps and you will be insured with your system security.
