How can I recall one message sent from Lotus Notes
Hi All,
How can I recall one message sent from Lotus Notes, to someone out side office network, using outlook or other mail client?
Can you please help?
Hi All,
Hi Polison,
Lotus notes version 8 primarily supports this features.
Lotus notes 6.5, 7, 7.5 aren't supporting this features.
The steps to recall one message sent email
Step 1: Open up the Sent view of your Lotus Notes V8 mail file and highlight the mail you want to recall
Step 2: Click the Recall Message button in the Action bar.
Step 3: After clicking OK, the recall request is accepted with a dialog box.
Note: In case everything is established appropriately, the messages are deleted from the recipients’ mail. You obtain a report informing you which messages had been recalled or not.
I hope it helps.
Thanks
Mary Jean
