How can I recover data from nokia n8?
I want to find a tool that will recover data from Nokia n8. I want to recover files, photos and music mp3. Is there one tool to recover all the data I want?
Hi Roger,
There are plenty of tools that can recover deleted data and files. But remember that file loss due to formatting or setting the device in factory setting is unrecoverable. Also, remember that after deleting data and the device receive other data, deleted hidden files may be over written so you must be careful if you are accidentally deleted the files you must not place other files in the device. These Tools/Softwares might help:
-Recuva (Recover any files: Video, Photo, Audio, etc.)
-WonderShare Photo Recovery (Only recover Photo, Available in Windows and Mac OS)
-Pandora Recovery
-Ashampoo Undeleter
Hope it'll help.
You can connect your Nokia N8 to computer as mass storage and run free program Recuva.
It works fine on any device connected to USB.
If the files you want to recover are stored in the internal memory, I don’t think there’s a way you can restore those files. Recovery is possible only if you store the files in the memory card. The Nokia N8 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies.
It was announced to the public on April 2010 and released on October 2010 measuring 113.5 x 59.1 x 12.9 millimeters and weighing 135 grams. It uses mini-SIM card. It has AMOLED capacitive touchscreen display with 16M colors at 360 x 640 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass.
It ships with Symbian^3 mobile operating system upgradable to Nokia Belle Refresh powered by 680 MHz ARM 11 processor and Broadcom BCM2727 GPU. It supports microSD expandable up to 32 GB. It runs on 256 MB RAM with 16 GB internal storage and 512 MB ROM.
The primary camera supports 12 megapixels with 1/1.83″ sensor size featuring Carl Zeiss optics, Xenon flash, autofocus, face detection, geo-tagging, and ND filter. It supports 720p video recording at 25 fps and 720p at 30 fps (via SW update). It has a secondary VGA videocall camera.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with UPnP technology support, Bluetooth 3.0 with A2DP support, GPS with A-GPS and Ovi Maps 3.0 support, stereo FM radio with RDS and FM transmitter support, and microUSB 2.0 with USB Host support. It has built-in accelerometer, proximity, and compass sensors.
The preinstalled web browser supports WAP 2.0/xHTML and HTML with Adobe Flash Lite support. Java is supported via MIDP 2.1. It runs on non-removable BL-4D Li-Ion 1200 mAh battery with standby time up to 390 hours on 2G and 400 hours on 3G. Talk time is up to 12 hours on 2G and 5 hours 50 minutes on 3G.
It is available in orange, pink, dark grey, silver white, bronze, green, and blue colors.
Notifications
