How can I recover deleted files in Windows?
By default when a file is deleted in Microsoft Windows 95 and higher it's automatically sent to the Windows Recycle Bin in case it needs to be recovered if the file was mistakenly deleted. Below are the simple steps that can be followed to recover those files if they were mistakenly deleted.
3a. Highlight the files you wish to restore, right-click the file and select the Restore option. This will restore the file from the original location it was deleted.
3b. Highlight the files you wish to restore, right-click the file and select Cut. Next, explore to the location you wish to move the deleted item to and click Paste.
3c. Drag-and-drop the icons from the Recycle Bin to the folder you wish them to be stored at.
If the Recycle Bin is empty you may have enabled Windows to not send the file to the Recycle Bin or it's more likely that the Recycling bin has already been emptied by you or someone else who uses the computer. If files are seen in the Recycling bin but not an older file you're looking for it's likely that older file has been removed to make room for other deleted files.
To recover the deleted files from the windows just simply use the Pandora Recovery because he/his allow you find the deleted file and recoverable from the NTFS-formatted volumes you can recover like your picture, song, movies or other documents.
If it not just try the TOKIWA Data Recovery this software is freeware and if you accidentally delete a files in the recycle bin.
It support FAT12, FAT16, FAT32 and NTFS even the NTFS compressed files in both side to the EFS encrypted files.
