I have a laptop that has Windows 7 on it and I accidentally deleted some files from the recycle bin that I needed. Where do these files go? They are really important for me. Can I recover them? Is there a good software that can help me with doing this task? Please help.
How can i recover files after they are deleted from recycle bin?
Once deleted from the recycle bin you can only use third party software to recover them. You can try using applications such as Recuva, Puran File Recovery, Glary Undelete, Pandora Recovery, Soft Perfect File Recovery, and EaseUS Data Recovery Wizard. I tried using Pandora Recovery and EaseUS Data Recovery and both applications are user friendly and all of those applications are free. You can Google them out to compare and get download links.
