How can I recover lost or deleted files easily?
Simply follow these instructions:
1. Download & Install any recovery utility. You can search for a free recovery utility in any search engine.
2. Open it and follow wizard steps.
3. Choose files and recover them.
That's it.
Dear Abigail
The files or data that you delete from any partition of hard drive, remains in the internal memory of hard drive until & unless other data is not written on these sectors. If your important files have been deleted intentionally or unintentionally, first make sure that you did not write / save / copy any data to that partition. If you place any data in that particular partition then it is very difficult to restore, recover the data.
Anyhow, if you have not written any thing in that partition then firstly, come to know that which file system is running on your hard disk partition (FAT or NTFS). Download or Purchase the "Get Data Back for FAT" or " Get Data Back for NTFS". Install the software, activate it or register it for better performance. Now give it the path of deleted file's partition and recover all lost files. Remember, you must save the recovered files in another partition.
Another software for best performance of recovery is known as " R-Studio Data Recovery 2.0". It is beneficial because it recovers data from the root of the hard disk's partition.
Dear Abigail Ann,
First, let me ask you a few questions. Â What are the important files that you have deleted? If they are just document files, jpg files, or maybe folders that contain small amounts of bytes. Â
The files that you deleted will still be in your Recycle Bin. Â All deleted files not more than what is specified in your setting, will be directed to your Recycle Bin. Â As far as I know, the computer will prompt you, when you delete a large bytes file, whenever the files are not directed to the Bin. Â In that case, you can recover it by clicking your Recycle Bin icon, after that you can see all of your deleted files, just choose the file and right click, choose RESTORE, it will be restored to its the original place.
Hope it will help a bit.
Hello,Â
You can recover lost or deleted files, by just simply installing, "Recover My Files". This software will recover lost or deleted files. The Recover My Files is fast and easy to use, because it can manage all your deleted important  files or recover the data back. This software performs on a hard drive,unformatted files or any removable media.
If you want, you may just pick any tool and try to scan the hard drive for the deleted files or data and get hold of your lost or missing files. On complete scanning, try to look into the list of jumbled file names.
There are also other ways that will help you recover your files quite easily and effectively.
