HELLO !
I have deleted some data files by mistake and I also deleted them from the recycle bin. It's been 2 days now and I am in real need of that data file. How can I recover my files data ? Which software is best for this purpose ?
How can I Recover my files data ?
Hi Dorothy Gallardo
Want to recover your file? There are many software that can help you to recover your file, I am not insured you that these softwares will must recover your file as well you want. Personally I have some experience about lost my important file before my last deadline of assignment. You can use “Recuva free software”. Personally I have used it and it was able to fulfill my requirement.
Here a link: http://www.piriform.com/recuva/download
Best of luck
Hello, Dorothy
Hope you are fine.
If you want to recover your deleted data then you can use many recovery software. Here you will get some software
Free Undelet
It is a useful tool to recover your deleted files including files deleted from windows or recycle bin. This software supports FAT32, NTFS, FAT16, FAT12 file system.
If it fails to work then you should take help from recovery specialist company like
Datacenter Professional Data Recovery
It is well known company that provides many IT related services including data recovery.
Hope you will get your answer.
