Ayswaria
Posted on - 08/02/2013
How can i recover my windows logging password which i lost forever which i cannot open for a three months
There is actually no problem even if you lost the password you used to log in to Windows, there is always a way of fixing it using available software. It is always legal to fix your own password but just make sure that it is really your password and not others. Anyway, here are some of the best tools you can use:
Offline NT Password & Registry Editor – this is probably one of the fastest password recovery tools available. The only problem you might encounter when using it is when accidentally resetting the passwords on users that have EFS encrypted files. If the operating system is Windows XP or even later, all encrypted files might become unreadable and unrecoverable unless you know the old password. Also visit About.com – PC Support | Offline NT Password & Registry Editor for additional information.
PC Login Now – one of the best free Windows Password Recovery programs. This program does not recover password, instead it displays your present Windows password. PC Login will delete it and lets you access Windows without needing to enter your password. After that, it will let you create new one.
