How can i recover password of rar file?
There is no known ways to do it.
Password combination can be found using bruteforce method: https://en.wikipedia.org/wiki/Brute-force_attack
But the last one method require powerful CPU and a lot of time for check every possible password from the list.
Quick way to get rar password doesn't exist.
RAR is a zip folders file system. That means you compressed some file with software or default windows system. Then when you are trying to unzip them you forgot your password. If I am right then you have this way to recover your password.
You need password recovery software for it. Go this link http://download.cnet.com/s/rar-password-recovery/ and download RAR password recovery software. Then install it and recover your password.
The other way is you can also break this password and set a new password. For that you also need password breaker software for RAR file. Go this link and download this software. http://download.cnet.com/WinRAR-Password-Cracker/3000-2092_4-75794719.html. then use it to break your password.
