alex6
30 points
Posted on - 09/03/2011
I want to remove the following from the top of my articles in my Joomla website.
Category: categary_2
Published on Friday, 12 August 2011 07:40
Written by admin
Hits: 96
I have looked in the admin panel, but haven't found a solution.
I've installed Joomla 1.7 and have added a template for my Joomla website.
Can some one help?
Thank You.
How can I Remove publish date, category from joomla ?
Follow these simple steps.
1. Open the page you want to edit through the Article Manager by clicking Content in the Article Manager menu item
2. After opening the Article Manager, Locate the Title of the Article to be edited.
3. Click on Parameters then Advanced pane In the Parameters Section of the Edit Article screen.
4. Finally, locate the Author Name, Created Date and Time and Modified Date and Time drop down fields in the Parameters list
5. Change it to Hide and you are done
Go the post that you are going to edit. Now that you have opened the Article Manager, go to the Title of the article. Left Click on Parameters>Advanced pane>Parameters Section of the Edit Article screen. In the end locate the Author Name, Created Date and Time and Modified Date and time drop down fields etc. in the Parameters list. And change it to Hide. I hope this helped.
Peter franklin
