gran wesner
20 points
Posted on - 04/30/2013
Hallo Guys!
I found this search qu toolbar installed on my computer running Windows 7 professional. The toolbar causes some uncalled for redirects and it has also taken over as the default search engine.
To make it worse, it has also replaced my home page settings automatically.
How can I remove the search qu toolbar for Windows 7 using Internet Explorer 9 browser?
Urgent, please.
How can I remove search qu toolbar for Windows 7?
Hello Gran,
You sure a not alone with this problem as there a many being affected by searchqu.To uninstall searchqu, get a genuine anti-malware if you don't have one and do a full system scan.I'll advice you use wondershare https://www.wondershare.net/ad/1-click-pc-care/?gclid=CLry-I6W9bYCFe3MtAodpzkAhA. This should uninstall searchqu from your computer.
If it doesn't,then follow these steps to do it manually:
1.Click on the START button and select CONTROL PANEL then ADD/REMOVE PROGRAMS.
2.With Windows Vista or 7,select CONTROL PANEL then UNINSTALL PROGRAM.
3.Search for searchqu and iLivid in the list. Highlightthe program(s) using your mouse printer and click the REMOVE or UNINSTALL button if your are using Windows Vista or 7.
To uninstall searchqu from your browser,
1.Open the browser.Go to TOOLS then MANAGE ADD-ONS.
2.Select TOOLBARS AND EXTENSIONS.Disable any item related to searchqu from the list; Searchqu toolbar,Bandoo Media,UrlHelper class,iLivid, etc,
3.Select SEARCH PROVIDERS.You may choose anyone but you may use Bing search engine.You must first make it your default search provider,then select WEB SEARCH and click DISABLE SUGGESTIONS to disable it.
4.Finally go to TOOLS,then INTERNET OPTIONS.Select the GENERAL tab and click use default button or enter the website you want for your homepage.
That's more or less it about the un-installation.
Searchqu Toolbar is an adware program that changes your browser homepage, default search engine and causes browsing redirects. Apart from these changes, Searchqu adds a useless toolbar on your browser and whenever you are doing a search, it displays in the first position an affiliate link. The Searchqu Toolbar gets to your computer after you have installed another program that had bundled in their installer the Searchqu Toolbar. Always pay attention when installing software because often, a software installer includes optional installs, such as this Searchqu Toolbar. Always opt for the custom installation and deselect anything that is not familiar, especially optional software that you never wanted to download and install in the first place.
How to remove Searchqu Toolbar:
1. Uninstall Searchqu from your computer To uninstall Searchqu program from your computer, click the Start > Control Panel > Uninstall a program. Search and uninstall Searchqu toolbar, iLivid, BrowserProtect and Search-Results toolbar from your computer.
2. Remove the Searchqu residual damage from your browser. Remove Searchqu from Internet Explorer. Open Internet Explorer, click on the gear icon (Tools for Windows XP users) at the top (far right), then click again on Internet Options. Now in the Internet Options dialog box, click on the Advanced tab, then click on the Reset button. In the Reset Internet Explorer settings section, check the Delete personal settings box, and then click on Reset.
When Internet Explorer finishes resetting, click Close in the confirmation dialog box and then click OK.
Close and open Internet Explorer again. Thanks.
Searchqu Toolbar is an adware program that changes your browser homepage, default search engine and causes browsing redirects, adds a useless toolbar on your browser and whenever you are doing a search, it displays in the first position an affiliate link.
How to remove Search qu Toolbar:
Uninstall Search qu from your computer
Click the Start > Control Panel > Uninstall a program. Search and uninstall Searchqu toolbar and Search-Results toolbar from your computer.
Remove the Search qu from your browser (Internet Explorer).
Open Internet Explorer, click on the gear icon at the top right> Internet Options>Advanced tab>Reset.  In the Reset Internet Explorer settings section, check the ‘Delete personal settings’ box, and Reset.
When done resetting, close the confirmation dialog box, click OK, Close and open Internet Explorer again.
