How can i remove unwanted Wireless connections in Windows 8
Windows 8 not sure why forget wireless has been removed
Please give me the steps from windows 8 as well as dos
Hi!
Steps for removing unwanted wireless internet connections in Windows 8 are listed below:
1. Click on Network Connection icon that are located in the bottom right-hand corner of screen.
2. You'll see many networks that you don't know and want to remove. Right click on them.
3. Select forget this network once you have right clicked on the networks that you want to remove.
4. There you go, only your desired internet connections are appeared.
