How can i remove websearch toolbar
Hello!
Good day!
I’m using Windows XP in my computer.
My browser is Mozilla Firefox4.
The problem is my browser showing a “Websearch Toolbar”, and I want to remove it.
Please guide me…
Thanks…
Hello!
Good day!
Please guide me…
Thanks…
Hello Dolores,
There's Adware, spyware or malware that is installed in your system that's why you have that kind of tool bar.To be able to remove web search tool bar on your Firefox, you can do the following steps:
For more information about installing and uninstalling toolbars, please visit the link below:
http://kb.mozillazine.org/Uninstalling_toolbars
-Zorian
Hello to you Dolore,
You can remove any tool bar that you do not want in the browser. Just use the following simple procedure to remove the websearch tool bar:
You will have successfully disabled your websearch tool bar.
__
Regards
Mahesh Babu
