How can I repair Mac pixel? Is there any Mac pixel repairer?
I need to repair mac pixel that are stuck at my screen. Is there an application that I can use to do that, or should I take it to service?
Best Answer by lieseljs
Answered By 0 points N/A #134851
Hi Richard!
You can try fixing the stuck pixels by using Pixel Fix. It is a widget that allows you to unfreeze pixels. Run the widget and scroll through the colors until the frozen pixels unlock. It may take more than one use to unlock the stuck pixels, but be careful not to overuse it because overstressing pixels can freeze them in rare cases. You can download the widget in this download link:
If it still won’t fix the problem, then bring your laptop to the Apple Service Center.
Answered By 0 points N/A #134852
Hi Richard M Logan.
Below are a couple of options to try.
1) Turn off your screen.
1.2) Get a damp cloth.
1.3) Apply pressure on the affected area only. careful not to apply pressure anywhere else other than the dead pixel as this might affect the surrounding pixels.
1.4) Keep applying pressure, turn on your pc and screen.
1.5) Remove the pressure and the dead pixel should be gone.
2) There is an application called Pixel fix. It is a Dashboard widget. Once downloaded it's exclusive purpose is to cure stuck pixels. It does this by searching through colors. After several searches Pixel fix can generally fix those stuck pixels. Ps. this is free to download.
Link beneath.
3) Here is another option to look at. This site gives you easy step by step instructions.
I hope you find this information useful.
Liesel
