Hi people!
I have tried Microsoft Dynamics CRM and found it to be quite effective. I decided to purchase a full version and it also worked well for some time. I tried to modify registry files to create trace files to track any modifications done by MS CRM. This has caused the whole application to fail to work completely and I have no traces to track my way back. What do I have to do to avoid a complete new setup?
How can I repair Microsoft Dynamics CRM registry?
Hi Gregory,
Now that you don't want to reinstall the setup you can easily then use the repair option instead of uninstalling and re-installing again. By following the following simple steps:
Click on start on your desktop
Hit the control panel
The dialog box will pop up
Go to programs change or uninstall
Click on the Microsoft dynamic CRM application and right click
change or uninstall pops up
Click on repair
And follow the onscreen instruction
Once done click on finish.
Incase the problem is not on the Microsoft dynamic CRM files but on the databases you have created then you will need to re-create the databases
