How Can I Reset My HP Laptop- Steps To Follow
I am using my laptop for several years. These days it starts hanging a lot, may be due to a lot of applications and use. How can I reset my HP laptop?
HP laptop has a feature of resetting it. It removes everything and helps in reinstalling Windows. Resetting is useful when you want to sell it. It removes everything including files, settings, and software apps.
Step 1: Turn on the HP laptop.
Step 2: Press F11.
Step 3: From "I Need Help Immediately", select System Recovery.
Step 4: Select Next after clicking "Back Up Your Files (Recommended)".
Step 5: After choosing a file, select Next.
Step 6: After selecting the drive, click Next.
Step 7: Choose Finish after completing the backup process.
