How can I reset a toshiba laptop to factory settings
130 points
Posted on - 04/18/2015
I want to restore the my toshiba laptop as some of the viruses are affecting the system battery I have saved the files that are important, I have also unistall all the anti viruses so it might not get the problem while doing the factory restore, but now i am not finding the way to do the restore factory setting please guide me to do it?
