Hallo!
I have created a message and converted it to image for sending using Zimbra. There is not extra text included in the message, it is only the photo. Can someone tell me how to resize photo message Zimbra? The reason I want it resized is because it is too big and therefore it cannot be viewed well on the desktop. Thanks, guys!
How can I resize photo message Zimbra application?
Unfortunately resizing an image attachment such as photos, is not possible with Zimbra, but there is a way to do that and I, think installing a third party resizing software will do the job.
FastStone is a free photo resizer application that i highly recommend.
Visit the download page here.
If the only thing in your image is text, then I do not recommend resizing or reshaping it, as it will most likely distort the text and make it unreadable. Ideally, you want to leave the picture as it was when you saved it, since there is no way to predict in which way the text will be affected when the image is resized.
