How can I resolve this error?
Hi experts,
I have a problem while downloading apps from the Google app Store. When I attempt to download app an error message appears. How can I resolve this error? Can you provide a solution to fix it? Any help would be really appreciated. Thanks in advance.
Update for “Gmail” could not be downloaded Due to an error.
Due to an error. (Error retrieving information
From server. [RPC:S-5:AEC-0])
OK
Answered By 5 points N/A #175661
Hi Scott,
You can follow these steps to fix your problem in downloading on play store:
Step 1: Log-in with your Gmail account then go to settings > accounts
Step 2: Select your Gmail account then go to menu then hit Remove account.
Step 3: Go to Apps > Playstore wipe data and cache.
Step 4: Restart your device the add your gmail account.
Or you can follow this another step:
Step 1: Go to your device Settings the select "Apps" and select "All"
Step 2: Select the "Google Play Store"
Step 3: Hit the "Clear Cache" then force Stop.
Step 4: Select the "Google Service Framework"
Step 5: Hit the "Clear Data" the Force Stop
Step 6: Restart your device.
I hope this can help you.
