Hello. I tried to play a movie on Xbox One, the 0x800c000b error displayed on my screen. I have tried reinstalling the application but, the error is not fixed. Please, suggest a way to resolve the error. Thank you.
How Can I Resolve The 0x800c000b Error Code?
Hello, learners. The 0x800c000b error code occurs on-screen whenever there is a glitch in the internet connection or not running smoothly. I’ve listed a few possible ways to fix the error; follow them.
Method 1:
Check the internet connection.
• Open Xbox One and go to settings.
• Then navigate to All settings -> Network -> Network Settings.
• Next, click on the test network connection and fix it if there is any problem.
Method 2:
Reboot Xbox.
• Press the power button of the PC for 10 – 15 seconds.
• Next, wait for it to shut down.
• Now, again restart the console and check if the error is fixed or not.
