I have dell laptop. I want to sale the laptop but I have lot of important data in it . I copied the data to my other laptop but i want to be sure that the data in my laptop should not be recovered. I deleted the data from the laptop know i want to restore the laptop into new condition as i bought it just know. Please can you guide me how to do that.
How can I restore dell laptop to factory settings
You can simply follow these steps,
First of all, restart the computer & while restarting, press the F8 key to open the Advanced Boot Options menu.
select Repair Your ComputerÂ
press Enter
select the language settings
select next
log in
select OK
select Dell Factory Image Restore
select next
select yes
select next
Once the restore is over, click Finish to restart the computer.
Best Regards!
"1. Endorsement important files and data. If you do not endorsement your files, you will lose them.
2. Turn off the PC
3. Separate everything, then the monitor, keyboard and mouse.
4. If your CPU is cropped, remove it from the docking place.
5. As the company logo appear on the screen, press F8 many times to open the Progressive Boot Options menu.
6. Use the Arrow key to go to Repair Your PC and before press Enter.
7. By entering into the System Recovery Options, select a the keyboard design and tick Next.
8. On the subsequent screen you can log in as a local user plus the Administrator.
9. Now it on your configuration you can check it by going into the Dell factory tools and Dell Factory Image Restore.
10. Tick Next to open the Settle Data Deletion menu.
11. Select the Absolutely, again format the derive and return system software to the new box condition and tick Resulting.
12. Later when the process is the complete then click on the option to the restart.
13. Return any data or programs you want from backup files.
