Tamanna 130 points N/APosted on - 04/29/2011
I was using Windows XP and it was good at the first time, However, Now I cannot use my Windows XP and it has many problems. Actually, I want to restore my Windows XP and want to use it like earlier date. If anybody help me to restore my system I would be grateful.
Start—>Programs—>Accessories—>System Tools—> System Restore. You can restore your system to any previous date where your system has made backup.
You can also optimized its storing features via Right Click on My Computer on Desktop then Select Properties then selecting first tab on top System Restore.
Go to start>all programs>accessories>system tools> then select system restore
then you have 2 choose between restore my computer to an earlier time or create a restore point
select restore my computer to an earlier time, then click next
Scroll back to the date you wish to restore to then click next.
The computer will start to shutdown, then it will restart by itself and automatically proceed restoring to the previous date
Let me know if you will encounter any problems. I will gladly help =)
If you want to restore your computer to a previous date, you need to perform a system restore and that is easy but it will depend on the availability of restore points created on your computer. To restore a computer to a previous date, a restore point is required. By default, your machine automatically creates restore points or system checkpoints.
To perform a system restore on your computer, click “Start,” “All Programs,” “Accessories,” “System Tools,” and then “System Restore.” On the next screen, select “Restore my computer to an earlier time” then click “Next.” On the next screen, select a date and check if there is a restore point available. Dates that have available restore points are normally highlighted on the calendar.
Select a restore point
If restore points are available, select one then click “Next” and then follow the instructions. Restart your computer if you are prompted.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
