How can I restore from paye tools backups?
Hallo there.
I am having serious issues with my application, though I have PAYE tools backups that I have run. I have kept the backups regularly and therefore a recovery will provide indemnity to my system. What I do not know is how to restore from PAYE tools backups. Can someone please tell me how I can restore using the backups step by step? Thank you so very much.
Answered By 0 points N/A #143166
Hi Gwendolynhunterr
It's recommended that when you are operating your own payroll using the database & other tools in this package, it's important to save  all the data in your employer Database after every pay period. In order to backup the data, click Restore the Employer Database/Back-up at the bottom left hand corner of the screen window below the 'Employer' & 'Employees' tabs. Then the option to back-up or restore the Employer database appears.
Good luck.
