How can I retrieve deleted files from a USB flash drive?
Need help from the expert! I do have a SD card which I bought a few months ago. I use it as storage for my movies, pictures and some important files. Recently I try to delete some files because I ‘m almost out of memory storage. The problem is I included some important files. I try to check the recycle bin if my files are there and restored it but there are no files available. I try to find file restoration software in the net but none of them seems to work.
The worst part is I downloaded software that is attached with a malware, thanks god my malware protection program blocked it before it can cause serious damage to my system Is there any legitimate software for file restoration? If I reformat a device is it still possible to retrieve deleted files?
I’m going to reformat my SD card but I hesitate to take action I might not able to retrieve my files forever. I need to retrieve it first and save a back-up file before I reformat my SD card. Please provide me instruction how to restore my deleted files.
