jeff mathie
30 points
Posted on - 08/21/2012
Hi, Iam trying to run RSBOT on my MAC. But an error message is popping up and the RS BOT is not running. How can I run RSBOT on my MAC?
The Java Jar file "RSBot-4025.jar" could not be launched.
Check the console for possible error message.
I think it is a very simple problem. But it needs solution. Because any problem is complex and vexing before solving. So, let's get a quick solution of your problem.
To get rid of the problem what you will have to do is just use Lion or Mountain Lion.
I think your problem must be solved.
Hathy
A JAR file (*.jar) is a Java file. JAR stands for “Java Archive” and is a file format that contains bundled Java class files together with associated sound or image files, metadata, and resources. A JAR file is actually just a ZIP file. It is normally a single, compressed file often used for providing necessary Java libraries and application software through a Java programming platform.
Since you are trying to execute a JAR file, it will not work if you don’t have JRE or Java Runtime Environment installed on your computer. To fix the problem and be able to run the file, download Java SE Runtime Environment 9 and install it on your Mac. Version 9 of Java Runtime Environment supports only 64-bit platform.
If you have a computer that needs the 32-bit version of the platform, download Java SE Runtime Environment 8.
