Hi experts
When I want to run a thermocouple task on a machine, such as the PXIe-4353, which utilizes a CJC channel on a new machine, I get the following error message
Error:
DAQ Assistant Error
Error -201426 occurred at DAQ Assistant
Possible Reason(s):
One or more devices do not support multidevice tasks.
Device: PXI1s1ot6
How can I run thermocouple task on a machine
The above error message which you received is highlighting that the pinpointed devices are affected the by the error. In order to resolve this issue, you need to replace the effected devices with those which support multidevice tasks. Please see the below link which describe the product families which its support tasks.
Hi Robert,
The error is because the software to support the multi device tasks is missing.
To resolve this error follow the procedure as stated below:
1) The product families that support the task are listed below.
a) C Series modules in the same chassis
b) X Series data acquisition module
c) DSA data acquisition module
d) S Series devices
e) SC Express data acquisition module
2) Select the one which suites the system configuration, install them
