How can I salvage some lost data and pictures
I am trying to salvage some lost data, how do I go about it? I realized I had misplaced some pictures while carrying out a system recovery on my computer. I had only backed up a few of them. My computer is of HP type and the pictures lost were for about six months.
Thank you for your help.
Best Answer by kasunklg
Answered By 0 points N/A #150519
Hi Jay!
You can try retrieving your lost data by downloading one of these applications. Here is a list and their links:
  1. PC Inspector File Recovery
  2. Recuva
  3. Active Undelete
  4. Pandora Recovery
  5. EaseUS Data Recovery Wizard
They are file recovery software that can retrieve up to 99% of lost data. You can download all of them to compare their performance and see which retrieves the most number of files.
Answered By 0 points N/A #150520
Activate the “Search tool” and Search the misplaced files carefully.
You can use image format extensions for the key words, like “.jpg” “.gif” “.png” to find pictures
After search is finished, check carefully your misplaced pictures found or not, if you found them “right click” on a picture and choose “open containing Folder” now select your pictures and copy them to elsewhere.
If it is not, try “Advanced search” and include “Hidden and System Folders” and search again using the upper mentioned procedure.
If it is still not, try a software like “Free Un-delete” to get the permanently deleted data.
