How can I save all images in my mails to Google docs?
I have an email id where many reporters send there images to be published on the news pages. I wanted to maintain them easily. Is there a way to save the images automatically on Google drive as we receive these emails?
Best Answer by Aron Hank
Answered By 0 points N/A #199100
You can save your Gmail attachments automatically in Google drive by running this script.
This will open Gmail login page, Login your Gmail account and click the Authorize button. This will provide your approval to run the script.
Next, you will be presented a form. Enter the name of folder in your Google drive, where you want your images to be transferred.
The script will label the mails which have been scanned by the script and the attachments transferred. You may also change the default name of the label; the default name is Processed.
Click the Start Button to run the script in background. The script will transfer all your old and new attachments to the specified Google drive folder.
You can also see the script to allow only specified attached images  to be send to the Google drive.
Alternatively, you can also look at the method developed by Amit Agarwal to achieve the same.
Answered By 40 points N/A #126441
Hello G.Adam,
You can easily send your images or other attachments to Google Drive by simply adding the file or folder that you receive under the Google Drive Label and it will automatically send all those files to your Google Drive.
Alternatively you can run Amit Agarwal's Script to do the job for you but it requires running the script each time you need to do the job.
