How can i secure my wireless network from attack wlan ?
Hi, I am worried about attack wlan because its business security matter. Please tell me how can i prevent attack wlan.Â
Hi. 🙂
See to it that you have protected your connections from various intruders especially those host or users that knows the password of your wifi connection.
Hope this helps you. Good day!
Hi Linalou,
There are many ways on how to protect your wireless lan from attacking your network. Here are some of the solutions that secure your network from intruders;
1.     Set a strong password for your Wireless LAN.
2.     Set IP to limit the number of users in your network.
3.     Set up parental controls within the network by configuring it on you network hub or transmission medium.
4.     Install network monitored software on your network server to monitor the activity and connected users on the network. Follow the link below to download the network monitoring software.
