How can I see all drives available on my computer?
Hello Juisaha,
To see all the drives that are available on your computer, just go to start on your computer system and then click on my computer. There you should see all the hard drives that are available on your computer which will include the USB drives, the DVD drives and the al hard disk drives.
You can also view your drives by going to disk management option of your computer. On your computer, click on start, then type computer management in the blank search field and then press enter on your keyboard.
In the message box that comes up next, look for disk management and click on it. There you will see all the drives that are available on your computer, and you can also change the letters to those drives from here.
__
Regards
Lee Hung
To be able to see all the drives, meaning to say the drive letters and partitions, opening up Computer or My Computer should show you all the available drives that you have. This may not show the drives that haven’t been formatted you or is labeled as Unallocated Space, you can then try and check your computer’s Disk Management utility, if you’re using Windows. To open it, right click on My Computer, or Computer, then choose Manage. It will open the Computer Management window, click on Disk Management. It will then show you your hard drive/s as well as how these hard drives are partitioned.
Thank you. Hope this helps.
Clair june
