How Can I See Which Android Version Is In My Mobile?
Different mobile is built with different android versions based on its advancement in the field of technology. How can I see which android version is in my mobile? Explain the procedure with steps to see the android version.
Answered By 0 points N/A #318738
Go to settings in your mobile. Click on system and then navigate to about phone. There we can find an option of android version. Continuously keep tapping on it. Then another screen will emerge that will show you the android version in your mobile phone.
Take for example your mobile is EMUI version 8.0.0 and hence android version 8.0.0. On clicking continuously over android version text in your settings we will get an image emerged which represents OREO android version. Clicking on it again continuously a flexible moved octopus game is obtained which is just an advancement of fun part.
