How can I send SMS from my Android phone to my computer?
I want to send sms from my Android phone to my computer. Is there any application to do that? My phone is the HTC Hero.
Want to send SMS form android mobile through pc use droid messenger you need to download it from website I mentioned. messages sent will be shown in website with your account first register or create account in droid messenger and then login with credentials and open website in your phone and send SMS to computer. otherwise go to mighty text and send SMS from phone with instructions mentioned.
Hope these shall helps you
Hi Richard,
It is possible to send SMS from your Android Phone to your computer or vice versa. You only have to install an application to your Android phone. Recommended to use is the Mighty Text application. First thing you should do is download the application and install it in your Android phone. Then you can start sending SMS in your computer into the android phone by visiting the website given by the application.
Hope it'll help and enjoy.
Ok the entire first you must have a valid data service in-between your PC and HTC hero. Then go to Google play or android market and download Tango Text, Voice, Video Calls or simply the name is tango. You have to be a registered user for both end in your PC and your Mobile to use this software. Tango can be found in the marketplace by a easy search.
