How can I set the form layout in email?
I have the same InfoPath form. When I preview test send while in InfoPath Designer 2010, I received the email with the form in the nice format, same as it was shown in design.
I published it to SharePoint InfoPath form service web browser form and it showed on the screen correctly but once submitted to my email, it was very wide.
How can I set the form layout sent from SharePoint web browser form to the same as designed to my email?
Answered By 5 points N/A #95443
If you want to set a form layout, you need to fix a pixel length. For this reason you can size the cell. You can fix it to 100% cell.
To fix your problem the best way is to use any website which will allow you to customize your layout. For example, you can use this site (click FormLogix Online Form Builder to go to the site) to customize your email layout simply and easily.
If you want to change your form layout then follow these steps:
  • Go to form settings.
  • Click "customize user email.
  • Enter the text which you want to appear in your customized email.
  • Choose variable like name, instance, and you can also insert text.
  • Click "edit text" for style text.
  • After completing, click"save"
You can also use Google groups to set the form layout you want.
