Hallo Guys!
I have built a website meant for alerting the citizenry on possible disasters and providing remedy information. I would like to include Natural Disaster Mind Map so that it can be easily accessible without having to switch to another website. How can I incorporate this map application into my website? Thanks a lot.
How can I set up Natural Disaster Mind Map on a Website?
Hi Harvey Logan,
Here is a simple step for you to embed a map into your website:
Make sure that your map shows in the map display.
Click insert picture at the upper left panel of the screen.
Copy the HTML under “Paste HTML to embed in website” box that will appear, then make sure to paste it also in the source code.
If you want a more detailed map that can be dragged or zoomed you can use JavaScript to show your map. You can use OpenLayers is always the choice of these features.
You can view an example's here: OpenLayers Simple Example 1
Or if you want a more advance map integration see OpenLayers Marker Example 2 and
Openlayers POI layer example 3
